jericho Posted June 18, 2009 Share Posted June 18, 2009 I am trying to find a poly-v pulley to mount on a 20mm parallel keyed shaft. Ive done a google,and phoned a few local companies,but so far no luck;plenty of v-belt pulley suppliers,but not so many poly-v. Pulley type required - PK7 at around 150mm diameter.That is the same profile as the pulleys on a 300tdi. The common way to mount pulleys to a keyed shaft appears to be taper-lock bushes,so what I need is - a 150mm PK7 taper-lock pulley. Any suggestions? Quote Link to comment Share on other sites More sharing options...
FKD Posted June 18, 2009 Share Posted June 18, 2009 These boys should be able to help clicky will send next day if you ask nice! Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 19, 2009 Share Posted June 19, 2009 Or these chaps - sold me stuff to convert a lathe to poly vee drive, can get taperlock bushes, bearings, pulleys belts etc and are dead helpful chaps http://www.pts-oldham.co.uk/ Nigel Quote Link to comment Share on other sites More sharing options...
jericho Posted June 20, 2009 Author Share Posted June 20, 2009 Still no luck after phoning several more suppliers. It seams that k section belts are for automotive applications rather that industrial,so the likelyhood of finding one to suit is small. Looks like I will have to make one myself by turning down a taperlock pulley,and cutting the centre out of one of the 300tdi pulleys. Quote Link to comment Share on other sites More sharing options...
