Chassis rot - MOT failure?
Its coming up to MOT time and I have some stuff to do on the 110 as usual. There are some parts of the chassis that got advisories on the last MOT which I would like your opinions on please:
Near side body outrigger corroded/weak:
Off side body outrigger corroded/weak:
Hole in chassis rail by fuel tank:
So what I'd like to know is whether or not these are just advisories or whether they are fails.
Would definitely say its time for you to learn to weld :o or
Find a friend who can for a few beer tokens :lol: or
Pay a fortune in a commercial garage etc :angry:
Clean it all up and yes hit it with a hammer around the chassis find out how much actually needs replacing.
The outriggers are about £12 each and simple to do.
But if you intend keeping LRs then buy a good MIG and learn to weld, you will need it it the future, i hate to think what repairs would have cost me over the years if i had to pay a welder for every time i wanted something fixing. If you do get a MIG their are some good articles on the forum about them, all i would say is stay away from the gasless MIGs.
Regards
Keith
Bottom 3 pictures are a definite fail, 'cos they are holes. Heavy rust that significantly weakens the metal, but do not perforate it are still a fail, but generally are just an advisory. Jab at the metal with a blunt screwdriver to see if it goes through or easily deforms.
To get it through the MOT -
1st pic - You can seam weld a flat plate right along the bottom of the outrigger - repairing it is very difficult. Alternatively - replace the outrigger.
2nd pic - Pretty much the same thing, but make sure the body support is in good condition.
3rd/4th pic - ARB brackets, which you don't use, so cut them off and then weld a plate to continue the bottom of the chassis - it's far easier than trying to do a decent repair in that pokey little hole.
Les.
  • 2 weeks later...
I've cut off the antiroll bar bracket and plated the chassis so the hole is fixed but now I need to replace the body outriggers. Can you buy replacement brackets that bolt to the top of the outriggers? The ones I have look pretty rusty and the replacement outriggers I bought don't have the brackets. I've looked on the sites I normally use for parts but can't find any.
