Freebie engine problems
bobtail84
The wife's cousin has a 01 3 door petrol freebie and it's ticking at the top end, using oil and water. This is as she described it over the phone to me and I'm going to have a look in the morning. I don't think it's a V6 so I'm assuming it's an 1800 but I don't know much about freebies. Any thought's or advice and thing's to look out for would be appreciated.
Jeff
Jeff
If its using oil and water its most likely to be a head gaskit issue.
If it's a 1.8 and hasn't been boiled yet then catch it quick, do the proper head gasket fix and fit the stat relocation kit if it hasn't already got it and keep your fingers crossed. Apparently if you boil them the heads go soft and you'll never make it last even with the uprated gasket.
For good advice and things like heads, check www.dvapower.com.
