minivin Posted March 20, 2006 Share Posted March 20, 2006 Got the 109 on the road at 13:00 yesterday, went to Sidbury which is all of 8 miles from me, went around a friends and showed them, then upto RogueTroopers and showed him, home and a quick wash down, this morning drove it into work, AND IT'S BROKEN DOWN ALREADY!!!!!! Was showing two friends around it (one had a 109, the other has a 90 and a 101FC), got to the end and Steve said "fire it up!", "click" hot plugs, moved the key the next position and <silence> nothing Pulled the wire off the starter motor and tested for the starter signal, yup, 12Volts, so after a bit of beating it with a broom handle I'm just going to go look for a hammer to beat that effing starter motor with. Aint even been on the road for 24Hours Quote Link to comment Share on other sites More sharing options...
Cartman Posted March 20, 2006 Share Posted March 20, 2006 Got the 109 on the road at 13:00 yesterday, went to Sidbury which is all of 8 miles from me, went around a friends and showed them, then upto RogueTroopers and showed him, home and a quick wash down, this morning drove it into work, AND IT'S BROKEN DOWN ALREADY!!!!!!Was showing two friends around it (one had a 109, the other has a 90 and a 101FC), got to the end and Steve said "fire it up!", "click" hot plugs, moved the key the next position and <silence> nothing Pulled the wire off the starter motor and tested for the starter signal, yup, 12Volts, so after a bit of beating it with a broom handle I'm just going to go look for a hammer to beat that effing starter motor with. Aint even been on the road for 24Hours Welcome to the world of LR ownership! Remember next time to take No.1 tool - 2lb lump hammer! Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 Welcome to the world of LR ownership! Remember next time to take No.1 tool - 2lb lump hammer! just had my contractor holding the ignition on the starter position as I hit it with a small ball peen hammer, it then threw-in and started will have to do the same proceedure for going home tonight and then it can sit on the drive as I figure whether to strip the starter or find another secondhand item cheap Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 20, 2006 Share Posted March 20, 2006 You saying that, I did notice that the started sounded rough when you started it leaving me. If you need another we can take it off mine and you can "borrow" it. Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 You saying that, I did notice that the started sounded rough when you started it leaving me.If you need another we can take it off mine and you can "borrow" it. Might take you up on that offer, what time you finishing work and how long can I borrow it? Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 20, 2006 Share Posted March 20, 2006 Superb!!!! Welcome to the joys of unreliable transport ownership! See now why were telling you to shake out the bugs for a few weeks? Jon Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 Superb!!!!Welcome to the joys of unreliable transport ownership! See now why were telling you to shake out the bugs for a few weeks? Jon And hence why I have absolutely no plans on selling the BMW as it's reliable Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 20, 2006 Share Posted March 20, 2006 Might take you up on that offer, what time you finishing work and how long can I borrow it? Let me move mine around tonight, and I will let you know, as for time.........untill you find a replacement!! Just give me the old one so at least I can fit it and get it to start if I need too!! Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 Let me move mine around tonight, and I will let you know, as for time.........untill you find a replacement!!Just give me the old one so at least I can fit it and get it to start if I need too!! ah kay Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 Well, just about to learn how to have a vehicle towed, and how to bump start it on a gradient, I'll let you know what I have learnt in an hours time Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 well, snapped a tow rope but it started, now sat on the drive in disgrace bloody thing, suppose I had better go pull the motor off Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 20, 2006 Share Posted March 20, 2006 Will be fixed tomorrow Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 It's kernackered only one brush is working in the slipring as everything is rusted, amazed it even worked solenoid dog engagement arm was stiff which explained why it wasn't throwing-in when it should Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 20, 2006 Share Posted March 20, 2006 Nothing a quick clean up and bit of lubrication wont fix then! Jon Quote Link to comment Share on other sites More sharing options...
minivin Posted March 20, 2006 Author Share Posted March 20, 2006 plus new bearings, new brushes as only one was working due to the new slip-ring assembly required as all the fixings have rusted solid, new stator assembly due to wear. Sourced another 2nd hand one for the moment as don't fancy paying out £80 for a service exchanged item Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 21, 2006 Share Posted March 21, 2006 You got a starting handle havnt you???? hahahahahahhahahahahhahahaha Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 You got a starting handle havnt you????hahahahahahhahahahahhahahaha But I got a Sherpa lump with no engagement dog hahahaoooooh Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 21, 2006 Share Posted March 21, 2006 Borrow Mandy's dog then! :-p Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 Borrow Mandy's dog then! :-p Got enough problems with a 109 eating my funds let alone a mad dog eating my slippers Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted March 21, 2006 Share Posted March 21, 2006 Did you get another starter? Quote Link to comment Share on other sites More sharing options...
eyore Posted March 21, 2006 Share Posted March 21, 2006 OOps,Lucky you weren't on your way to catch the ferry on your trip to Italy Anyway,hopefully its just a minor glitch Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 Did you get another starter? will hopefully know tonight Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 OOps,Lucky you weren't on your way to catch the ferry on your trip to Italy Anyway,hopefully its just a minor glitch Hopefully have it sorted tonight, wonder what's next to break........ Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 make that possibly tomorrow night, or the weekend <sigh> Quote Link to comment Share on other sites More sharing options...
minivin Posted March 21, 2006 Author Share Posted March 21, 2006 starter motors totaled, stripped, cleaned, reassembled, dead. Quote Link to comment Share on other sites More sharing options...
