mpb Posted July 1, 2009 Share Posted July 1, 2009 I have a 1996 Defender 90 that is fitted with a 4 bolt steering box. The steering has gone heavy. I've jacked up both front wheels & the steering is still heavy. So i disconnected the steering drag link & the steering felt notchy & heavy. the power steering res is full of fluid & it did overflow while testing the steering. Moving it from lock to lock. There are no leaks of the pump or the box. Do you think the pump or box are at fault? Can the box be adjusted in situe or do I buy a recon box? Many thanks Quote Link to comment Share on other sites More sharing options...
disco tony Posted July 1, 2009 Share Posted July 1, 2009 not an expert with hubs but couldn't it also be railko bushes gone? Check for play, top/bottom wiggle, with wheels raised. (Or I could be talking carp and wait for a grown up ) Quote Link to comment Share on other sites More sharing options...
western Posted July 1, 2009 Share Posted July 1, 2009 try lubricating the column UJ's with WD40 or similar, they do dry out & can cause stiffness. Quote Link to comment Share on other sites More sharing options...
mpb Posted July 2, 2009 Author Share Posted July 2, 2009 try lubricating the column UJ's with WD40 or similar, they do dry out & can cause stiffness. stuck a load of WD40 on theUJ's this morning & left it to soak in. It felt a lot better this evening, so a big thank you to Western. Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2009 Share Posted July 3, 2009 glad it helped Quote Link to comment Share on other sites More sharing options...
pedro Posted July 3, 2009 Share Posted July 3, 2009 Hello, dont know if helps but had the same problem with 110. I have owned it for 3 years and always thought that the steering was just heavy! Until i drove my friends Td5. The fluid in mine was always full. I bought a new steering box and what can i say except obviously the old box never worked properly, it feels like a new car! The box was around 80 quid and took about 3 hrs to fit, it is quite heavy so watch fingers! I believe there is a seal kit, so my old one is now for sale if anybody wants. Quote Link to comment Share on other sites More sharing options...
