Rolly Posted July 10, 2009 Share Posted July 10, 2009 Got a friend who imports this stuff in from the states (Amsoils) so I can get it at a reasonable price. It's supposed to make the engine & transmission run cooler with less friction and give a longer life between changes and even have a small but positive influence on fuel economy & power. Anyone tried them in their Landrover? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 10, 2009 Share Posted July 10, 2009 A lot of oils are synthetic anyway - Td5 engine oils for example - so it isn't really a new thing Quote Link to comment Share on other sites More sharing options...
Paul Posted July 15, 2009 Share Posted July 15, 2009 For Australia, yes absolutley. I just replied on another thread about the salisbury diff getting hot - the use of a fully synthetic oil made a significant difference to the temp of the diff. Full synthetic oil also made a big difference to the noise level from the transfer case. I currently use Castrol SAF-XA 75w140 in front and rear axles, swivels and transfer case. Castrol Syntrans (not syntrax) 75w85 in the gearbox and Caltex Delo 400 in the engine. Quote Link to comment Share on other sites More sharing options...
landy andy. Posted July 15, 2009 Share Posted July 15, 2009 Only use fully synth in everything on my Def, including Difflock Oils in the boxes and diffs. Wow what a improvement. Andy Quote Link to comment Share on other sites More sharing options...
Rolly Posted July 15, 2009 Author Share Posted July 15, 2009 For Australia, yes absolutley.I just replied on another thread about the salisbury diff getting hot - the use of a fully synthetic oil made a significant difference to the temp of the diff. Full synthetic oil also made a big difference to the noise level from the transfer case. I currently use Castrol SAF-XA 75w140 in front and rear axles, swivels and transfer case. Castrol Syntrans (not syntrax) 75w85 in the gearbox and Caltex Delo 400 in the engine. Only use fully synth in everything on my Def, including Difflock Oils in the boxes and diffs. Wow what a improvement.Andy Sounds good, I'll have to give it a try. Quote Link to comment Share on other sites More sharing options...
