alfaman Posted July 11, 2009 Share Posted July 11, 2009 Hi, I'm asking this on behalf of a mate of mine. The side of his Landy is wet around the filler area, mostly noticeable when the tank is full. Any ideas? We've changed the filler cap twice (1st didn't seal properly ). He's changed the diaphragm on the fuel pump (previous advice from another Landy owner). All the pipework has been checked and double checked, all the filler pipework to the tank has been replaced. Stumped! Keith. Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2009 Share Posted July 11, 2009 mine gets wet on the outer body panel filler recess ith a full tank, try bending the cap lugs so it grips tighter. are the rubber pipe jubilee clips tight? Quote Link to comment Share on other sites More sharing options...
alfaman Posted July 11, 2009 Author Share Posted July 11, 2009 mine gets wet on the outer body panel filler recess ith a full tank, try bending the cap lugs so it grips tighter.are the rubber pipe jubilee clips tight? Tried that, no change and changed it. All are tight and they've all been replaced with new ones. Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2009 Share Posted July 11, 2009 are the breather pipes clear & not kinked. Quote Link to comment Share on other sites More sharing options...
alfaman Posted July 11, 2009 Author Share Posted July 11, 2009 are the breather pipes clear & not kinked. Erm, if your referring to the ones on the block? The breather has been changed and the pipes. If not, those have been changed too. Quote Link to comment Share on other sites More sharing options...
poohbear Posted July 12, 2009 Share Posted July 12, 2009 I found that my filler neck was perforated - sympton was a puddle of fuel under the truck following an drive when tank was over half full, no staining on outside of vehicle by filler cap though. D. Quote Link to comment Share on other sites More sharing options...
western Posted July 12, 2009 Share Posted July 12, 2009 Erm, if your referring to the ones on the block? The breather has been changed and the pipes.If not, those have been changed too. fuel tank breather pipes I meant Quote Link to comment Share on other sites More sharing options...
