Defender alloy wheel
Bluemoon
You don't - they are the same wheels and the same part numbers. The weight rating is just different between the different types - some types are OK to use on a 90 or a Discovery only, other types are OK on a 110 as well. The only Genuine alloys that are 100% OK on a 110 are the Boost and Deep Dish, some of the aftermarket copies of the others (Tornado/Freestyle) say they are OK on 110s as well.
What's the specific issue?
Yep, Bish is right - the only genuine wheels that are 100% approved are Deep Dish and Boost, both of which were also fitted to late model 97/98 Tdi Discoverys at different times.
There isn't much in it - the other wheels (e.g. Tornados) are rated to be at least OK for a Discovery Tdi with a max rear axle load of 1650kg while a 110SW has a max rear axle load of 1850kg and probably typically runs at about 1000kg-1200kg lightly loaded so in practice unless you run fully laden in the 110 it will be fine - but it doesn't meet the specs.
I wouldn't recommend it at all :ph34r:
