steve_a Posted July 27, 2009 Share Posted July 27, 2009 As part of the repair work on the Discovery 2 I had to remove the master cylinder, and I managed to snap the one way valve during the process. Microcat doesn't have the part number listed - so wondering if someone knew it? They are probably all the same, but it's 99 Discovery 2, ABS. There are no part numbers on the actual valve, just marked made in Germany. If you have part numbers for earlier servos post em up, because if they are cheap I'll get a few thrown in when I do the order from the UK next week. Quote Link to comment Share on other sites More sharing options...
white90 Posted July 27, 2009 Share Posted July 27, 2009 disco 1 is stc780 but this part does not appear in the D2 section Quote Link to comment Share on other sites More sharing options...
steve_a Posted November 22, 2009 Author Share Posted November 22, 2009 STC493 is a workable replacement it turns out, or at least that is what I used last week. The section going into the servo fits, however the pipe connector is about the same size as the pipe, I used another bit of pipe which fit over both to join and butted them against each other. Brakes have loads of stopping power again. Still not the right part though, and I wonder if some of the others would work as well. Quote Link to comment Share on other sites More sharing options...
western Posted November 22, 2009 Share Posted November 22, 2009 Valve is most likely part of the vacuum hose from the vac pump on back of alternator & not available as a seperate part, I haven't found it either. Quote Link to comment Share on other sites More sharing options...
