defender dinky Posted July 29, 2009 Share Posted July 29, 2009 hi all, rescently upgraded to 200tdi very pleased with outcome changed gearbox transferbox and engine,now gear sticks sit further back can't get middle seat in anymore, would a cubby box still fit, [don't want to buy if not] tried a centre console out of disco i'm breaking fits ok but abit short at front bulkhead could get round it i suppose bit of handy work, has anybody done same conversion, any idea's and photo's would be great cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted July 29, 2009 Share Posted July 29, 2009 Did you use a disco gearbox? Dave. Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2009 Share Posted July 29, 2009 swap the main gearbox for the correct 90/110 main gearbox or remove/strip/rebuild the Disco box with the correct defender parts. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 29, 2009 Author Share Posted July 29, 2009 swap the main gearbox for the correct 90/110 main gearbox or remove/strip/rebuild the Disco box with the correct defender parts. hi, yes i used disco gearbox because the shaft was worn on the defender box, as to stripping the gearboxes down sounds to complicated for me being a novice,using disco gearbox i had to move engine mounts forward, so don't fancy moving them back now, is there a archive on stripping the gear boxes. cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
western Posted July 29, 2009 Share Posted July 29, 2009 don't know of a thread showing how to change the gearbox bits over from a defender to discovery box. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted July 29, 2009 Share Posted July 29, 2009 It would proberly be easyer as western said to get another box and move the mounts back to their original position, otherwise its proberly a case of having to live with it. If you do want to change the box layout then Ashcrofts are the people to speak to. http://www.ashcroft-transmissions.co.uk/ Dave. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 29, 2009 Author Share Posted July 29, 2009 It would proberly be easyer as western said to get another box and move the mounts back to their original position, otherwise its proberly a case of having to live with it.If you do want to change the box layout then Ashcrofts are the people to speak to. http://www.ashcroft-transmissions.co.uk/ Dave. hi dave, it dose'nt bother me i was just wondering if anybody had got any idea's how i could finish off the centre console area, would a cubby box still fit as anybody got the dimensions for cubbybox, i'm happy with set up as is, drives great cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted July 29, 2009 Share Posted July 29, 2009 I have got a cubby box, I think its an exmoor trim one, It takes up almost all of the space between the seats however it is sat a little bit forward so I can rest my arm on it. This is the one i have.......as you can see from the photo it takes up quite a large amount of space, not sure how much space you have? http://www.trakkers.co.uk/defender-style-cubby-1189-0.html Dave. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted July 29, 2009 Share Posted July 29, 2009 I think if you used a R380 defender box, rather than an LT77, you can leave the mounts in their current position. Quote Link to comment Share on other sites More sharing options...
