need4speed Posted August 14, 2009 Share Posted August 14, 2009 The bottom edge (where they are held by the little bracket) of both my defender front wings is a bit corroded/chewed up. Can they be repaired or is it a case of replacing? Has anyone tried the ABS outer wings? How is the fit/finish against the wing tops? Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2009 Share Posted August 14, 2009 make up a suitable angled section to fit on top [inside] & rivet/seal it to the original panel Quote Link to comment Share on other sites More sharing options...
The Badger Posted August 15, 2009 Share Posted August 15, 2009 If you want you can replace them with plastic ABS ones, or just do what western says. Quote Link to comment Share on other sites More sharing options...
paul the plumber Posted August 16, 2009 Share Posted August 16, 2009 make up a suitable angled section to fit on top [inside] & rivet/seal it to the original panel sounds the best idea Quote Link to comment Share on other sites More sharing options...
