Matthew Posted August 25, 2009 Share Posted August 25, 2009 Hi all. I've got a set of Procomp shocks that are going to be replaced under warranty, only thing is I need to give them the numbers stamped on the shock casing. Mine are incredibly rusty and I can't make them out. Could someone with Gwyn's kit front and rear OR the same pin/eye configuration please let me know what numbers are stamped on the front and rear casings? thanks, matt Quote Link to comment Share on other sites More sharing options...
mick110 Posted August 25, 2009 Share Posted August 25, 2009 Hi all. I've got a set of Procomp shocks that are going to be replaced under warranty, only thing is I need to give them the numbers stamped on the shock casing. Mine are incredibly rusty and I can't make them out. Could someone with Gwyn's kit front and rear OR the same pin/eye configuration please let me know what numbers are stamped on the front and rear casings? thanks, matt Procomp again?...not top mounting eye sheared was it? Quote Link to comment Share on other sites More sharing options...
iomlt Posted August 25, 2009 Share Posted August 25, 2009 Procomp again?...not top mounting eye sheared was it? Over tighhtern? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 25, 2009 Share Posted August 25, 2009 +5 Pin > Pin or +5 Loop > Pin ? Advise and I'll check me "Usefully stored stuff" and post up Nige Quote Link to comment Share on other sites More sharing options...
Matthew Posted August 26, 2009 Author Share Posted August 26, 2009 I've had these shocks for over 6 years and they've had a pretty rough time throughout, no problem with the mountings, they just don't provide effective dampening any more. If you leave the vehicle over night for the first 3-5 minutes of driving its very bouncy, then seems to get better. I know some have had loads of issues with Procomp shocks, but in my experience with them I've been reasonably impressed, especially when you consider how cheap they are, 6 years of use isn't that bad! I'll need +5 pin > pin, if anyone’s got the numbers stamped on the casing it'd be very much appreciated. Cheers! Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted August 26, 2009 Share Posted August 26, 2009 6 years of use isn't that bad! 6 years of use and they are to be replaced under warrenty??!! Well Done!!! How did you manage that?? Quote Link to comment Share on other sites More sharing options...
Matthew Posted August 26, 2009 Author Share Posted August 26, 2009 Lifetime warranty Quote Link to comment Share on other sites More sharing options...
roachy Posted August 27, 2009 Share Posted August 27, 2009 please elaborate, i have a set of these that are leaking after 4 uses. do you have a contact number or e-mail? any help appreciated. the numbers stamped on mine are 92656 OE12096 and C249A3 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 27, 2009 Share Posted August 27, 2009 P/N is 926560 Nige Quote Link to comment Share on other sites More sharing options...
