nige90 Posted October 6, 2009 Share Posted October 6, 2009 ...............exiting through the rear crossmember cause exhaust fumes to be drawn in through the rear when the canvas window is rolled up ? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 6, 2009 Share Posted October 6, 2009 Yup Nige Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 6, 2009 Share Posted October 6, 2009 ...............exiting through the rear crossmember cause exhaust fumes to be drawn in through the rear when the canvas window is rolled up ? It happens with a side exit pipe too... Quote Link to comment Share on other sites More sharing options...
Quagmire Posted October 6, 2009 Share Posted October 6, 2009 With my standard exit pipe you still get a bit of exhaust sucked in when you lift off, even with the canvas rolled down. This is made much worse if you open the windows- but goes away completely if you open the bulkhead vents On LPG the smell is OK, and you dont smell like an old car when you get to where you are going... Quote Link to comment Share on other sites More sharing options...
