Retroanaconda Posted October 8, 2009 Share Posted October 8, 2009 Hello all, I have mounted my NATO hitch as per this link: http://www.retroanaconda.com/landrover/?p=52 Now, with a piece of 12mm steel behind there I very much doubt it is going to pull through, but I have noticed it's nigh-on impossible to do the bolts up properly as the crossmember is just crushing inwards. My question is, should there be crush tubes in there for the NATO hitch holes? Many thanks Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted October 8, 2009 Share Posted October 8, 2009 Yup there should be crush tubes or more likely a '#' shaped noughts and crosses grid inside, if you have a carp aftermarket xmember these wont be there and will lead to it distorting, also I think technically you are advised to fit the nato hitch with 2 sets of nuts... Mike Quote Link to comment Share on other sites More sharing options...
TD5 power Posted October 8, 2009 Share Posted October 8, 2009 hi yes you definitely need crush tubes in there, have a look at les's write up here HTH matt Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 8, 2009 Author Share Posted October 8, 2009 Bugger, this isn't the first issue that I've had with this crossmember. Damn cheapo previous owner ¬_¬ How do you mean two sets of nuts? The second set acting as locknuts? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 8, 2009 Share Posted October 8, 2009 Yes I used to just use Nylocs though Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted October 9, 2009 Author Share Posted October 9, 2009 Yeah, well that's what I've done. As for the crush tubes, well I'll have to try and get some added at some point. It'll have to do as it for now though. Thanks all. Quote Link to comment Share on other sites More sharing options...
