Posted
Hi all..
Can anyone tell me the timken/gkn part number for swivel pin bearings? I've got a really good bearing suppler near me but he won't understand the Land Rover part numbers :)
I'm using TD5 90 axles.
Cheers, matt
Posted
I can give you an MNR bearing number if that helps......dont have any Timken's in stock
MNRS 11520....think there the bottom ones as there are 2 different sizes
Hope that helps
Posted
thanks for the reply. I don't think my supplier has MNR bearings (aren't they made in india? any good?) I've always used Timken bearings and they seem to last ok.
Just need to find the part number for the top and bottom bearings....I see Les is using them here in his tech thread (http://forums.lr4x4.com/index.php?showtopic=5601) any chance of a part number Les?
Cheers, matt.
Posted
Matt
Ralph (Western) is away, otherwise he would have most probably come your rescue by now.
He should be back in a week.
Les usually checks in at lunchtime and late afternoon.
Why not send him a PM in case he misses this thread.
John
Posted
Thanks John, I did wonder where Ralph was today - doesn't normally take him long when it comes to part numbers!
Errol, thanks for the link, site looks very useful!
Posted
Not sure if it helps but I have 4 timken bearings here I bought to do my disco but on inspection someone has retrofitted ABS type housings which have a completely different set up. Thus I have a set of 4 brand new timken bearings which may be what you need. Can post to you for a few beer tokens if they turn out to be what you are after.
Cheers
Mark
Posted
Cheers
Mark
Cheers mark, that could be perfect.
I'll try and identify which Timken part number I need then we will know if yours are the same. Looking at the website I think it might be set 37? But I'm not 100% sure I put the right details in....I'm not sure what year of vehicle my axles would've come from. My 90 is 1986, but the axles are from a TD5.
Cheers,
matt
