big ives Posted October 22, 2009 Share Posted October 22, 2009 hello my mate has broken his CV joints on his 1987 90 TD, quick question i have a spare axle from a 1992 200tdi Disco 1, can i use the CVs and shafts of this axle to help him out and rebuild his axle?????????????????????? many thanks Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted October 22, 2009 Share Posted October 22, 2009 IIRC......NO......the cv joint is too long but you could change the full axle over. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted October 22, 2009 Share Posted October 22, 2009 Its too early to think of technical questions......to use the disco axle internals you will need to change the half shaft, cv joint, stub axle, hub and maybe the disc/caliper too. Quote Link to comment Share on other sites More sharing options...
damio Posted October 22, 2009 Share Posted October 22, 2009 had the same problem but with a 200tdi D90 and a 200tdi discovery axle. The internals are different but the whole axle fits, the only difference is that the mounts of the radius arms are bigger on the disco axle so I had to change the bolts and use some spacers. You also need to use the defender brake pipes, from the calipers up. Quote Link to comment Share on other sites More sharing options...
big ives Posted October 22, 2009 Author Share Posted October 22, 2009 Its too early to think of technical questions......to use the disco axle internals you will need to change the half shaft, cv joint, stub axle, hub and maybe the disc/caliper too. K88MUD so will the disco axle fit straight onto the 90? i will not be able to get a look at either axles until next week, i am just doing my homework to see what would be the cheapest solution for him, again thanks for the info Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 22, 2009 Share Posted October 22, 2009 CV joints are in region of £25 each, and take approxiametly 2hours each to change, why do want to be swapping axles?? Quote Link to comment Share on other sites More sharing options...
big ives Posted October 22, 2009 Author Share Posted October 22, 2009 CV joints are in region of £25 each, and take approxiametly 2hours each to change, why do want to be swapping axles?? ejparrott he has just broken them, i have not yet seen what is broken, i think its the cv joint, but might also be the halfshafts as stated just doing my home work so i can help him when i get back, if its just the one cv then clearly a new one is the cheapest option. as i had a spare axle i was just checking if it would be quicker for me to change as i do all his work, and at no cost to my mate................ many thanks Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted October 22, 2009 Share Posted October 22, 2009 Yes the disco axle will fit straight on. Dave. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 22, 2009 Share Posted October 22, 2009 Yes the disco axle will fit straight on. Dave. IF the radius arms are the same width. Of course, if oyu have the Disco radius arms too then this will not be a problem... Quote Link to comment Share on other sites More sharing options...
big ives Posted October 23, 2009 Author Share Posted October 23, 2009 thanks to everyone for the info changing the axle might be the quickest way to go, will see..............thanks Quote Link to comment Share on other sites More sharing options...
