Divster Posted October 25, 2009 Share Posted October 25, 2009 Fr some reason my D2 has developed a bit of a problem in the last day or two. After a run out I go to lock the car using the plipper. The horn sounds (as if I've left a door open) and refuses to lock. When this normally happens (I leave the back door open for the dogs on hot days)using the key in the drivers door barrel will lock all doors but de-activate the motion sensors inside. However, at the moment only the drivers door will lock. I've checked that all of the doors and bonnet are shut. The central locking fuse is OK. A new battery has recently been put into the plipper. The fault is intermitant as I returned to the car an hour later and it would lock and unlok without issue, however after another short run out the same problem was evident. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Briandisco Posted October 26, 2009 Share Posted October 26, 2009 Just had something similar. Eventually needed a new BCU Brian Quote Link to comment Share on other sites More sharing options...
Divster Posted October 30, 2009 Author Share Posted October 30, 2009 Does anyone know if a new BCU is simply plug and play or will it require use of a diagnostics unit to make it work? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 31, 2009 Share Posted October 31, 2009 You will need a Testbook/IDS or similar. I don't know which of the toy computers will do it, I suspect a Nanocom won't, but the more advanced ones like Autologic almost certainly do, no experience of any of them. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted October 31, 2009 Share Posted October 31, 2009 get the ecu fault read as you can test each door and operation which will then tell you which catch has failed. the problem with the bcu is they fill with water due to the sceen leaking remove the bcu and check for water ingress Quote Link to comment Share on other sites More sharing options...
landi41 Posted November 1, 2009 Share Posted November 1, 2009 Fr some reason my D2 has developed a bit of a problem in the last day or two. After a run out I go to lock the car using the plipper. The horn sounds (as if I've left a door open) and refuses to lock. When this normally happens (I leave the back door open for the dogs on hot days)using the key in the drivers door barrel will lock all doors but de-activate the motion sensors inside. However, at the moment only the drivers door will lock. I've checked that all of the doors and bonnet are shut. The central locking fuse is OK. A new battery has recently been put into the plipper. The fault is intermitant as I returned to the car an hour later and it would lock and unlok without issue, however after another short run out the same problem was evident. Any suggestions? This may be too easy but check your door switches, the driver's door in particular tends to break off the wire from the end of switch..... Quote Link to comment Share on other sites More sharing options...
vougese39 Posted November 1, 2009 Share Posted November 1, 2009 This may be too easy but check your door switches, the driver's door in particular tends to break off the wire from the end of switch..... as the switch is an interal part of the door catch don't see how this can apply? Quote Link to comment Share on other sites More sharing options...
martinhollings Posted November 1, 2009 Share Posted November 1, 2009 You will need a Testbook/IDS or similar. I don't know which of the toy computers will do it, I suspect a Nanocom won't, but the more advanced ones like Autologic almost certainly do, no experience of any of them. yes nanocom will i have done it you need to reprogram the key codes the emergency acess code the speedo milage and then you need learn security settings for the engine ecu and i bet there is some thing ive missed Quote Link to comment Share on other sites More sharing options...
landi41 Posted November 1, 2009 Share Posted November 1, 2009 as the switch is an interal part of the door catch don't see how this can apply? My bad on this one. I was referring to a D-1, should have payed more attention ....Good Luck with your problem.... Quote Link to comment Share on other sites More sharing options...
