Dash
I'm in the process of removing my dash on a 1994 defender 90.
The bit I'm having a little trouble removing is the grey trim that is infront of the the vents/flaps. I have pulled out the 2 large grey plugs however there seems to be 5 or so little grey plastic nail looking things holding it in place along the bottom and they appear to go into the bulkhead.
Any help on removal and or part numbers to replace them as they seem pretty well stuck in, so I'm guessing they will need replacing afterwards?
Many thanks
Yep, pigs to get out. When I took mine off I used a pair of sidecutters as the sharp edge allowed me to get under the head, then a bit of levering and the correct swear word and off they came. Actually manged to re-use them but I think I was lucky.
:unsure:
Malcolm
