cipx2 Posted November 16, 2009 Share Posted November 16, 2009 Does anyone have a 200/300 tdi engine laying around and can measure the flywheel diameter for me, please? I'm interested in the diameter without the gear ring, like in the picture below. The measurement doesn't have to be very precise, a +/- 1 mm will suit me fine. The scaled pic gave me about 330 mm. TIA Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 16, 2009 Share Posted November 16, 2009 Got a spare TD one, which i think is the same as the 200tdi (might be wrong). I'll measure it when i get home later. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 16, 2009 Author Share Posted November 16, 2009 Yes, I think they have the same diameter. They share the same ring gear anyway. There's a difference re the timing slot but that's not important here. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted November 16, 2009 Share Posted November 16, 2009 Ive measured my TD and disco 200TDi as 310mm, so I'd agree they are the same and that is the size. I will admit though that the clutch is still fitted to the 200 and makes it slightly harder to measure, but if the part numbers for the starter rings are the same, I cant see there being a difference. HTH...BTW..whats the reason? Just curious!! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 16, 2009 Share Posted November 16, 2009 310mm across the clutch face of the flywheel. I'm not sure about a TD one being the same - flywheels have a specific bolt pattern so that they only go on one way to remain balanced to the crank. Les. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 16, 2009 Share Posted November 16, 2009 Les has beaten me to it Quote Link to comment Share on other sites More sharing options...
cipx2 Posted November 16, 2009 Author Share Posted November 16, 2009 Thank you both. Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2009 Share Posted November 16, 2009 2.5 TD Flywheel & 200Tdi flywheel use the same ring gear & the same bolt spacing & the same bolts. but because they are different engines the flywheel part number is different & clutch components are common too. Quote Link to comment Share on other sites More sharing options...
