PoguesTD5 Posted December 21, 2009 Share Posted December 21, 2009 Hi Guys, I've recently bought my D2 TD5 and its losing coolant, are there any common areas for failing and causing leaks. I looked under neath and I could see cooloant drips on the passenger side near to the front (if it helps) Any help would be great. Cheers Pogo Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 21, 2009 Share Posted December 21, 2009 Radiator by the sound of it - it is an alloy rad matrix crimped into plastic end tanks and they go around the crimp joint, quite a common fault. Should be able to see pink staining around the edges of the rad if so. Quote Link to comment Share on other sites More sharing options...
MartinK Posted December 22, 2009 Share Posted December 22, 2009 I also had a core plug weeping. It's very hard to get at (under the manifold)...so I used some "radweld"-type stuff, and it's been ok since! That was 80,000 miles ago. If the manifold ever comes off for any other reason, I'll fix the core plug, but until then... Quote Link to comment Share on other sites More sharing options...
Jimbo-TD5 Posted December 27, 2009 Share Posted December 27, 2009 mine was leaking from the fuel cooler on the left hand side, some rad weld type stuff sorted it out! The left engine mount was covered in the stuff! Quote Link to comment Share on other sites More sharing options...
