sweety Posted December 23, 2009 Share Posted December 23, 2009 I've just bought a tow ball/pin for my D2 to use as a rear recovery point only to find it doesn't fit & the reason I now know is that what I thought was the tow bar is in fact just the top mounting for a adjustable tow bar I was wondering if a tow bar off a D1 will fit onto a D2 as my local breakers has a few in at the min. The other option I can think of is to work with what i've got & wondered if widening the holes so that the tow ball bolts fit through the bracket with a 10mm plate on the other side would be ok & poss try & make something up to connect to the chassis as I have some 6mm checker plate. Great-full for any help as i've just had a huge bill for the D2 & am skint & will be for awhile now Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 24, 2009 Share Posted December 24, 2009 I think it will have to be type approved on a vehicle of that age so a made up job may not be OK with plod? The top bracket is different but I made up my own out of a LR drop plate kit and some scrap metal, no silly regs here. Quote Link to comment Share on other sites More sharing options...
sweety Posted December 24, 2009 Author Share Posted December 24, 2009 Thanks for that as I said it won't be used for towing any thing on the road it'll be just as a recovery point & for looping the dogs lead over so he don't do a runner when busy Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 24, 2009 Share Posted December 24, 2009 What does the law say about having a non approved tow bar on a vehicle if it isn't being used to tow at the time of inspection? Quote Link to comment Share on other sites More sharing options...
MrKev Posted December 24, 2009 Share Posted December 24, 2009 I thought it was now an MOT fail if the vehicle was post about '97, but http://www.motuk.co.uk/manual_660.htm doesn't seem to mention anything specific about type approved towbars. The test manual does say that whatever is fitted, even if there is no ball or pin attached, should still be adequate and appropriately constructed. I would think that this is the basis the plod would use at the side of the road, as if they're not satisfied, they can request an MOT retest be taken and invalidate your current one. Looking at the D2 down the road from me, and comparing to my D1 I can't see any obvious difference, but I can't exactly have a proper look, as it's not mine to take apart... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 24, 2009 Share Posted December 24, 2009 i imagine the D2 one would have to be longer, as the the extra length of the D2 is from the rear axle backwards. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 25, 2009 Share Posted December 25, 2009 Just from memory but I think the "swan neck" bracket that goes from the crossmember to the drop plate is quite a bit longer on a D2 version. Quote Link to comment Share on other sites More sharing options...
