Adam001 Posted December 31, 2009 Share Posted December 31, 2009 Hey, I recently finished a 200 disco engine conversion in my 110 (2.5TD 19J), it went well apart from the fuel pipes. I thought the 200 fuel fitler would be better so set about using that but neither the 200 or TD pipes seemed to do the job. I now have a horrid combination of fuel pipes, and I have been riddled with leaks What has everyone else done on the fuel pipe front while using the 200 disco fuel filter? Happy new year! Regards Adam Quote Link to comment Share on other sites More sharing options...
SiWhite Posted December 31, 2009 Share Posted December 31, 2009 If I remember correctly the fuel filter comes after the lift pump. I would use the discovery pipes from lift pump to filter to injector pump. The standard TD pipe should fit onto the lift pump without modification. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted December 31, 2009 Author Share Posted December 31, 2009 yeah the standard tank to lift pump pipe is fine, the problem one is the lift pump to filter line. the 200 line is too short to reach the bulkhead Quote Link to comment Share on other sites More sharing options...
Guppy Posted December 31, 2009 Share Posted December 31, 2009 For the price of a new pipe, and for piece of mind, you're better off simply buying one. It's only about a tenner. ESR267 is I believe the part number. It saves a great deal of hassle. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted December 31, 2009 Author Share Posted December 31, 2009 Oh ok, is that a disco or defender pipe? will it reach ok then? Quote Link to comment Share on other sites More sharing options...
4x4ledbury Posted December 31, 2009 Share Posted December 31, 2009 fuel filter to lift pump needs extending you can get fuel hose from any factors you got to now take the fuel return to back of ijection pump. where before it went to the top of cav filter iirc. but luckily the old 200 hose reaches from the fip to the filter .i tried bodging it up but i didnt work because with a direct injection the fuel at a higher pressure than a n/a deisel Quote Link to comment Share on other sites More sharing options...
Adam001 Posted January 1, 2010 Author Share Posted January 1, 2010 extending is what caused the problems, as the connection on the lift pump is the flared pipe type using the plastic pipe. so had to cut it and put fuel hose over it to extend it. Which standard pipe will do the trick? 200 disco or defender? where can I get it from? Cheers, Adam Quote Link to comment Share on other sites More sharing options...
LandyLee Posted January 1, 2010 Share Posted January 1, 2010 I`m showing ESR394 for defender 200 TDI lift pump to filter ,, is that the one you need? Quote Link to comment Share on other sites More sharing options...
Adam001 Posted January 10, 2010 Author Share Posted January 10, 2010 I`m showing ESR394 for defender 200 TDI lift pump to filter ,, is that the one you need? Sorry didn't notice this post, yes I believe that will be the one I need, thanks Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2010 Share Posted January 10, 2010 these might help. Quote Link to comment Share on other sites More sharing options...
