zim Posted January 6, 2010 Share Posted January 6, 2010 Evening, I'm putting my crower 50229 cam into my 4.2 lse engine. But i would like to put a new timing chain on at the same time. But not sure which one ??? Standard chain & nylon gear ? or these duplex items http://www.v8tuner.co.uk/product.php?id=699 or http://www.v8tuner.co.uk/product.php?id=97 or any other suggestions ? The engine is just going to be used in my offroader. Thanks Gordon Quote Link to comment Share on other sites More sharing options...
QTdarren Posted January 6, 2010 Share Posted January 6, 2010 hi mate , i ran the 60 squid type one , with a solid gear, for ages in my QT lasted for ages , drilled a small hole in the front of the block to aid oil flow to help keep it quiet / and lube , to be honest mate i dougbt you could here it any ways, and as you say its only in your off roader. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 6, 2010 Share Posted January 6, 2010 Both are good - more expensive is slighly better, but don't think either have nylon gears from memory - check If the cheap is steel solid gears and chain and no nylon then it will do handsomely on anything bar the true exotic, and it will be strong and protect from strech which affects timing, and nylon gears which wear and do the same, oh and sometimes shear / loose teeth Nige Quote Link to comment Share on other sites More sharing options...
zim Posted January 6, 2010 Author Share Posted January 6, 2010 more money gone tomorrow then Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 7, 2010 Share Posted January 7, 2010 Both good ........... but I always use the Cloyes with the Reynolds prestretched chain ......... the second of the above links. Quote Link to comment Share on other sites More sharing options...
zim Posted January 7, 2010 Author Share Posted January 7, 2010 thanks for the replies i've literally just got off the phone from ordering a : Rover V8 Cloyes "Street" Duplex Roller Chain Set Cloyes Duplex "Street" Roller Chain Set. Features Steel Gears with 3 position keyway for timing in your cam 4deg advance, retard or standard. Duplex pre-stretched roller chain. The street sets are a alternative to the more expensive true roller sets but at a more attractive price. Quote Link to comment Share on other sites More sharing options...
zim Posted February 12, 2010 Author Share Posted February 12, 2010 Evening, I've been at work for the last 3 weeks. So will be putting my engine together this week. The timing chain has come in, but could someone explain which markings i should use as a starting point ? Here is the pdf of instructions : http://www.cloyes.com/Portals/10/TechTips/HPTips/3%20keyway%20instructions%20%28general%29.pdf There are the options of GM and Chrysler or Ford ? I do realise that my cam needs to adjusted so that it opens and closes at the correct time, but am intersted in how a normal setup would be timed ? Cheers Gordon Edit : thinking about it - i can just put the old gears on and then hold that position whilst put on the new ones. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted February 13, 2010 Share Posted February 13, 2010 Exactly as the instructions say ………….. use the factory keyway (zero degrees cam) See here ….post #27 http://forums.lr4x4.com/index.php?showtopic=14006&st=20 Quote Link to comment Share on other sites More sharing options...
zim Posted February 13, 2010 Author Share Posted February 13, 2010 Thats an excellant thread Quote Link to comment Share on other sites More sharing options...
zim Posted February 21, 2010 Author Share Posted February 21, 2010 Cam retaining washer to stop forward movement : Cam machined to take a cam retaining washer : Bling Finding TDC with an extended DTI into cyl 1, the mark on the crank pulley was pretty close amazingly Quote Link to comment Share on other sites More sharing options...
