Mean Green Posted April 22, 2006 Share Posted April 22, 2006 Hi Ralph, I am looking for a bit of advice from you. You have a 200 Tdi coupled to an R380. I am in the process of changing the bulkhead on my 200 to a TD5 Style Bulkhead. I have come up against a problem. The Bulkhead does not fit over the LT77 without chopping it. As I see it I have 3 options .. 1. Chop the bulkhead 2. Fit a TD5 3. Couple an R380 to the 200 So...... I am examining the options for 1&2, but what about 3?? What is involved in changing from an LT77 to an R380 and couple it to a 200? Thanks Greg Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2006 Share Posted April 23, 2006 (edited) So......I am examining the options for 1&2, but what about 3?? What is involved in changing from an LT77 to an R380 and couple it to a 200? Thanks sorry for the delay, been out on a rally all weekend, with no internet access. IIRC my bulkhead hasn't been modified in any way, at least I've no record/invioce showing any gearbox tunnel bits. to mate a 200Tdi to a R380 use the 11cm long 'stumpy' bell housing, IIRC this is the existing LT77 part, LR part number is FRC9865 for gearbox serial number 50A [r380 serial number NOT lt77 my lt77 was 56A] this leaves the gearbox in the original location & locates the engine as per a genuine Defender 200Tdi factory built vehicle. hth Edited April 23, 2006 by western Quote Link to comment Share on other sites More sharing options...
Mean Green Posted April 23, 2006 Author Share Posted April 23, 2006 sorry for the delay, been out on a rally all weekend, with no internet access.IIRC my bulkhead hasn't been modified in any way, at least I've no record/invioce showing any gearbox tunnel bits. to mate a 200Tdi to a R380 use the 11cm long 'stumpy' bell housing, IIRC this is the existing LT77 part, LR part number is FRC9865 for gearbox serial number 50A [r380 serial number NOT lt77 my lt77 was 56A] this leaves the gearbox in the original location & locates the engine as per a genuine Defender 200Tdi factory built vehicle. hth Thanks Ralph. Decided just to chop the new bulkhead, and to be honest it was a fairly easy job, and when it sits beside the old you would hardly know it had been chopped. Cheers Greg Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2006 Share Posted April 23, 2006 Well sorted & without any wallet bashing too, top job Quote Link to comment Share on other sites More sharing options...
Mean Green Posted April 24, 2006 Author Share Posted April 24, 2006 Well sorted & without any wallet bashing too, top job Hmmm Dunno about that! The new bulkhead is different from the old one, so I will probably need to buy new things like a new wiper motor etc Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2006 Share Posted April 24, 2006 You may get away with using the existing items.can't be that much difference. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted April 24, 2006 Author Share Posted April 24, 2006 You may get away with using the existing items.can't be that much difference. Nah, knowing my luck I will end up spending a fortune that I dont have on stuff that I probably dont need! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 25, 2006 Share Posted April 25, 2006 I always thought it was just the "diaphram" bit that screws betwen the bulkhead and around the transmission tunnel that was the deciding factor as to what engine/gearbox combo was used? didn't realise that the metalwork on the bulkheads was different. Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2006 Share Posted April 25, 2006 DJ, I think the diaphragm bit was what MG meant, so far as I know the bulkhead are virtually the same for all. Quote Link to comment Share on other sites More sharing options...
pritch1 Posted April 25, 2006 Share Posted April 25, 2006 yea ive fitted a td5 bulkhead to my early 1985 90 and they switched no hassels at all Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2006 Share Posted April 25, 2006 Mean Green will give you a big wet sloppy kiss for that little gem, just what he wanted to know Quote Link to comment Share on other sites More sharing options...
Mean Green Posted April 25, 2006 Author Share Posted April 25, 2006 DJ, I think the diaphragm bit was what MG meant, so far as I know the bulkhead are virtually the same for all. Vitually the same, yes. An exact fit ... no! The transmission tunnel on the TD5 is different to the 200Tdi, I had to cut away a section around the tunnel. To be honest it was not too bad a job, as a rule I dont like drilling/cutting/grinding the body work on my baby... even less kean when it is a brand new bulkhead Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2006 Share Posted April 25, 2006 (edited) even less keen when it is a brand new bulkhead Extreme care taken then, good to hear it's sorted Edited April 25, 2006 by western Quote Link to comment Share on other sites More sharing options...
