H-M3 Posted January 10, 2010 Share Posted January 10, 2010 Hi peeps. happy new year. need some help plese, my RR has started to flash "air suspension inactive" message. This happened few weeks ago and had it reset was ok until today!Last time the diagnostic picked up code 51 kbus fault & code 116 "reservior pressure static when filling". can anyone shed any light on this as my rr is stuck on normal hight! thankinh you. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted January 10, 2010 Share Posted January 10, 2010 The K bus fault is usually water ingress in the headlight levelling ecu in the N/S A pillar - Standard fix is to throw that ecu away and move the plug away from the water drips.Then with Testbook reset the Body Control unit to "No Headlight levelling". The suspension inactive fault is usually one of two things.First is that early cars had a software fault and can be cured with a software reload using Testbook - but I would have thought most cars would have had that done by now.Second is that the air supply unit under the spare wheel in the back is wearing out - this is most likely. Quote Link to comment Share on other sites More sharing options...
vougese39 Posted February 7, 2010 Share Posted February 7, 2010 there was also a modified switch to go with the download too but if they have been done 99% new pump Quote Link to comment Share on other sites More sharing options...
SteveG Posted February 8, 2010 Share Posted February 8, 2010 from personal experience, faulty height sensor and water ingress into rear wheel well can cause this too. Quote Link to comment Share on other sites More sharing options...
QTdarren Posted February 8, 2010 Share Posted February 8, 2010 reservior pressure static when filling .its a dryer and exhaust ( on the comprser ) replacment / mod , only done by dealer . not sure on the other fault at the mo. if i can rember i will get the part numbers for you and post them here tomoz.and the TSB number. Quote Link to comment Share on other sites More sharing options...
