pugwash Posted April 24, 2006 Share Posted April 24, 2006 OK guys need some forum help here. For those interested in the waterproof switches which Simon and I are trying to sort out, can you tell me what sort of colours you think would be best. We have already decided on a black colour for the main portion of the switch (apart from engine start and hazard warning, both of which will be red)- with a lit red bar at the bottom of the switch, which lights up when the switch is activated. The bit we aren't sure about is the lit box at the top of the switch- this is the box that will have all the symbols printed, and can be lit all the time, or when you turn your lights on (however you decide to wire it) The poll is- what colour should this box at the top be? Quote Link to comment Share on other sites More sharing options...
02GF74 Posted April 24, 2006 Share Posted April 24, 2006 We have already decided on a black colour for the main portion of the switch (apart from engine start and hazard warning, both of which will be red)- with a lit red bar at the bottom of the switch, which lights up when the switch is activated. The bit we aren't sure about is the lit box at the top of the switch- this is the box that will have all the symbols printed, and can be lit all the time, or when you turn your lights on (however you decide to wire it) The poll is- what colour should this box at the top be? wot you say is the rocker (the bit you press) is black but the transparent window can be a different colour? I thought that the colour usually goes with the function of the switch, a bit like these: e.g. main beam blue, hazards red etc. (not sure what the tortoise and rabbit switches do?) and Quote Link to comment Share on other sites More sharing options...
pugwash Posted April 24, 2006 Author Share Posted April 24, 2006 wot you say is the rocker (the bit you press) is black but the transparent window can be a different colour?I thought that the colour usually goes with the function of the switch, a bit like these: e.g. main beam blue, hazards red etc. (not sure what the tortoise and rabbit switches do?) and Good point hadn't thought about that. i was asuuming that most people will want a set of switches which have a similar style! i kind of assumed that most people use their own current in-dash warning lights etc etc Quote Link to comment Share on other sites More sharing options...
darthdicky Posted April 24, 2006 Share Posted April 24, 2006 I voted green as I want them for lights, and if I ever get lockers I'd want them to be a different colour so that they stand out from the others. Different colours for different applications sounds best though. Richard Quote Link to comment Share on other sites More sharing options...
pritch1 Posted April 24, 2006 Share Posted April 24, 2006 yea thinking bout it different colours for different applications probably aint a bad idea. i voted green to match the land rover interior Quote Link to comment Share on other sites More sharing options...
