jamesvfr Posted January 23, 2010 Share Posted January 23, 2010 Hi all Just wondering if the part of the gearbox mount that bolts directly is the same on all manual discos, rangies + 90s? Only reason being i ripped out the old 2.25 petrol + lt77 a long time ago from a 90 my dad has as he wanted v8 auto, now getting back round to doing it again + he now wants v8 manual as we have an LT77 for a v8 in the shed but lost the mounts from the lt77 that was in it Ive got some from a 4speed rangie box + just wondered if they are the same + if the box would sit in the original place Cant move the engine mounts till the box is in to get a location Cheers all James Quote Link to comment Share on other sites More sharing options...
Eightpot Posted January 23, 2010 Share Posted January 23, 2010 you should be ok for that, I don't believe the gearbox mounting points ever shifted in 90's - but as you say will probably need to shift the engine mounts as the bellhousing will be a different length. Quote Link to comment Share on other sites More sharing options...
dirtbox Posted January 24, 2010 Share Posted January 24, 2010 Well, when I removed my 2.5 petrol and LT77 and fitted a 3.5 V8 with a santana (LT85), I just used the same mounts that were original. I did however have to use the mount attached to the LT77 so that both fixing points on the LT85 used the plate that directly has the rubber underneath rather than the plate that offsets the mount. If that makes any sense?? Can take some piccys tomorrow if you like. Quote Link to comment Share on other sites More sharing options...
jamesvfr Posted January 24, 2010 Author Share Posted January 24, 2010 I think that makes sense So basically both halves of the gearbox mount, each side of the rubber, were from the same box? Fingers crossed as said above the mounts didnt move on different 90's Cheers James Quote Link to comment Share on other sites More sharing options...
dirtbox Posted January 26, 2010 Share Posted January 26, 2010 Yeah you should be fine then as another way of looking at it; The mount bolted directly to the chassis on my 2.5 petrol stayed on. The replacement gearbox (LT85) side of things was just a flat plate with the rubber directly bolted to it. So if you have bits bolted to both boxes and your original chassis mounts still in place you should be fine! Quote Link to comment Share on other sites More sharing options...
