Orgasmic Farmer Posted February 7, 2010 Share Posted February 7, 2010 Am rebuilding a front axle and one side was a bet watery and the needle bearing race in the stub axle looked a bit corroded so I want to replace it to be sure its OK. I have the part but Haynes book of lies helpfully says i should entrust the job to me Land Rover dealership! So what difficulties should I be aware of and are there any helpful hints out there to make the job go smoothly. Thanks mark Quote Link to comment Share on other sites More sharing options...
p76rangie Posted February 7, 2010 Share Posted February 7, 2010 Am rebuilding a front axle and one side was a bet watery and the needle bearing race in the stub axle looked a bit corroded so I want to replace it to be sure its OK. I have the part but Haynes book of lies helpfully says i should entrust the job to me Land Rover dealership! So what difficulties should I be aware of and are there any helpful hints out there to make the job go smoothly. Thanks mark What vehicle are you talking about first Quote Link to comment Share on other sites More sharing options...
white90 Posted February 7, 2010 Share Posted February 7, 2010 James has Mark on his old TD5 90 Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 7, 2010 Share Posted February 7, 2010 Like this? http://forums.lr4x4.com/index.php?showtopic=8009 Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted February 7, 2010 Share Posted February 7, 2010 Hi Mark, seats looking good by the way, cheers. I was quite surprised to find this bearing, having not dismantled a 24 spline before but IIRC it had to come out in order to change one of the seals, it also does not come in the overhaul kit! I just used a pin punch I think and used the bearing to push the seal out with GENTLE use of landrovers favourite tool regreased and as the book of lies states 'refitting is a reverse of dismantling' Cheers Andy Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 7, 2010 Author Share Posted February 7, 2010 Thanks Andy, I will give it a go. Quagmire. that article is for the wheel bearigs which are inside the hub and not the stub axle. The bearings I need to change are a very thin needle bearing affair. On the earlier stub axles I see they have a bronze bush rather than a bearing in this location Quote Link to comment Share on other sites More sharing options...
Quagmire Posted February 7, 2010 Share Posted February 7, 2010 Ah, sorry - 07:19 must be too early for me to be posting in the mornings! Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted February 7, 2010 Author Share Posted February 7, 2010 Well have managed to get the seal and the bearing race out but still left with the outer race with no obvious way of removal. Looks like I will have to weld something to it and then knock it out. Unless someone knows another way? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 7, 2010 Share Posted February 7, 2010 Removal is easy Mark I just bent an old screw driver and tapped them out, I replaced them with bronze Maxi drive bushes so I can't comment on replacing the needle rollers James did this though. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted February 8, 2010 Share Posted February 8, 2010 can you get a long punch down the stub and try tap the outer race out ? in work we quite often fromve outer races from bling holes , by putting a few blobs of wels on the race , usally drop out with a tap on the housing . you could try knocking a sharp pin punch or small chisel between the outer race and the housing but i suspect the housing (stub axel) is sorter and will mark when i done mine it all knocked out from down the stub , fitting new one is easy , sutable socked and a press , or pieace of wood and tapp it home good look Quote Link to comment Share on other sites More sharing options...
