defender dinky Posted February 9, 2010 Share Posted February 9, 2010 hi all, trying to put my doors back on after rebuild but can't seem to get them to hang properly the way they came off, any ideas, cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
SiWhite Posted February 9, 2010 Share Posted February 9, 2010 Could I offer some advise? When posting questions such as these, you need to supply more information if you expect good, relevant help. For instance; Front doors? Second row doors? Rear door? Do the doors close? Have you changed the hinges? Is the problem one of 'up and down' alignment, or 'in and out'? Are you having problems getting the door to engage with the striker? Have you tried using the black plastic spacers behind the hinges? Have the captive nuts in the bulkhead been changed? Have you moved or removed the bulkhead? See what I mean? If your question had been more detailed, I'd be able to offer some advise.... Try using a jack to lift the rear edge of the door, bearing in mind the hinges have some play. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted February 9, 2010 Author Share Posted February 9, 2010 (edited) Could I offer some advise? When posting questions such as these, you need to supply more information if you expect good, relevant help. For instance; Front doors? Second row doors? Rear door? Do the doors close? Have you changed the hinges? Is the problem one of 'up and down' alignment, or 'in and out'? Are you having problems getting the door to engage with the striker? Have you tried using the black plastic spacers behind the hinges? Have the captive nuts in the bulkhead been changed? Have you moved or removed the bulkhead? See what I mean? If your question had been more detailed, I'd be able to offer some advise.... Try using a jack to lift the rear edge of the door, bearing in mind the hinges have some play. hi,front doors, doors close when picked upbut keep dropping,have not changed hinges,yes up and dqwn alignment,there were no black plastic spacers when i took them off,capive nuts have not been changed,yes bulkhead has being moved, spripped it all down for galv chassis cheer's defender dinky door card keeps catching sill, Edited February 9, 2010 by defender dinky Quote Link to comment Share on other sites More sharing options...
sgnas Posted February 9, 2010 Share Posted February 9, 2010 Either your hinges have too much wear in them or your bulkhead needs tipping forward a bit. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 9, 2010 Share Posted February 9, 2010 Hinges are just peanuts. Do some good to yourself by buying new ones. Alignments are knakkered Quote Link to comment Share on other sites More sharing options...
cieranc Posted February 9, 2010 Share Posted February 9, 2010 Seem to remember in several re-chassis write ups, that aligning the doors should be done before the bulkhead bottom bolts are tightened up, so you can pull the bulkhead into place to suit the doors and shim it up correctly? Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 9, 2010 Share Posted February 9, 2010 I have a simlar problem at the moment on my 90 (- although the doors didn't line up when I got it after it just had a semi re-build - not by me). I've been checking the parts manual out for a diagram of how the bulkhead is actually attached to the chassis, but can't find any decent graphics, does anyone have any pictures of the mounting points and or how the bulkhead is fixed. Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 10, 2010 Share Posted February 10, 2010 ok found some pictures, can anyone explain how you shim the bulkhead mounts, to be it looks like you just bolt it to a pre-defined turret type affair? Quote Link to comment Share on other sites More sharing options...
sgnas Posted February 10, 2010 Share Posted February 10, 2010 Front to rear alignment is just washers on the big bolts at the bottom. Vertical is by the flimsy bulkhead to chassis braces using thin (specific shape) shims. If these are not present, then it is your wings! Quote Link to comment Share on other sites More sharing options...
