landrover598 Posted May 1, 2006 Share Posted May 1, 2006 I'm looking for some +1" springs for the front of my defender, It's got a boat anchor (aka Tdi) and a 50Kg winch and bumper fitted. What options / brands are available ? Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2006 Share Posted May 1, 2006 OME 751's on the front of my 110 with TDi/husky winch/steel cable & bumper. http://members.shaw.ca/jbarge/springinfo.html Quote Link to comment Share on other sites More sharing options...
JST Posted May 2, 2006 Share Posted May 2, 2006 disco 1 tdi rears on the front worked well on my 110 with warn and bumper giving it +1" Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 2, 2006 Author Share Posted May 2, 2006 That sounds good I'd like to use standard LR springs if possible to keep cost down Have you got the specs for those springs ? thanks Quote Link to comment Share on other sites More sharing options...
inchman Posted May 2, 2006 Share Posted May 2, 2006 hello, i recently fitted a warn winch and heavy bumper to the front of my 90. I used range rover heavy duty springs and this levelled it up great, they are part number NRC4304 and are £9 from paddocks.. cheers Gary Quote Link to comment Share on other sites More sharing options...
JST Posted May 3, 2006 Share Posted May 3, 2006 Disco spring data these i beleive, although i cant remember the colours and i am afraid have passed the vehicle on now! data from here: Spring data Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 3, 2006 Author Share Posted May 3, 2006 Thanks Quote Link to comment Share on other sites More sharing options...
Diff Posted May 4, 2006 Share Posted May 4, 2006 Be careful! Those rear disco springs NRC 8045 and 8044 are standard 110 front springs too! They are progressive and as a result give the same ride height as a standard 90. I have them on my 110 as do all standard 110s. They won't give you a lift. There are other disco rears which might be more suitable. Perhaps they were the V8 '90-'93 NTC5527 rear red/pink springs? Regards, Diff Quote Link to comment Share on other sites More sharing options...
JST Posted May 4, 2006 Share Posted May 4, 2006 Diff, well they are the ones i fitted to the front of my 110 tdi with a warn 9000 and heavy duty bumper and it raised it 1" over std ride height (about 1.5" over what it was at the time i changed them) Quote Link to comment Share on other sites More sharing options...
Diff Posted May 4, 2006 Share Posted May 4, 2006 Diff,well they are the ones i fitted to the front of my 110 tdi with a warn 9000 and heavy duty bumper and it raised it 1" over std ride height (about 1.5" over what it was at the time i changed them) How odd! I can only think that your 110 must have had the wrong ones on originally, or old and saggy ones. As those springs are standard for the front of a 110 as mentioned, so should have been on there already. A standard 110 front like mine, doesn't sit any higher than a 90. A 90 has lighter springs than a 110, but are not progressive like the 110 ones. The 110 ones are progressive and the first three coils close up under the weight of the vehicle, so give the same overall height. The 110 springs shouldn't sag as much as the standard 90 springs when you put a winch on. Regards, Diff Quote Link to comment Share on other sites More sharing options...
