Igol Posted March 4, 2010 Share Posted March 4, 2010 I've managed to shear a rear wheel nut stud when I was swapping tyres. I'm assuming that it wont be a simple (cheap) case of replacing the stud and fitting a new one and I'll need a full hub as well as a wheel nut (the gods will make sure that it costs more in broken stud extractors than a new nut ever would). So far Googling 'rear wheel hubs' has given me a lot of wheel bearings but not the bit I want, should I be looking for some weird name other than hub like wheel retaining plate? Or if anyones got the part number Discos a 97 300tdi. Thanks Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 4, 2010 Share Posted March 4, 2010 stud should hammer out as IIRC they are a spline fit into the hub. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 4, 2010 Share Posted March 4, 2010 The studs are splined into the hub , you will have to remove hub+disc then take the disc off to fit the new one though Cheers Steveb Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 5, 2010 Share Posted March 5, 2010 Wheel stud is part No FRC5926. Knock the old one out, then pull the new one in using one of the wheel nuts. Les. Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted March 5, 2010 Share Posted March 5, 2010 if you have any thread left to screw an old nut on, hit the nut, it saves spreading the stud end. Quote Link to comment Share on other sites More sharing options...
Igol Posted March 5, 2010 Author Share Posted March 5, 2010 if you have any thread left to screw an old nut on, hit the nut, it saves spreading the stud end. Thanks everyone. A cheap fix, til something else breaks at least. Its a very neat shear so it will be a big hammer after all and a drift Quote Link to comment Share on other sites More sharing options...
