noise jammer Posted March 8, 2010 Share Posted March 8, 2010 I was wondering if I could trouble you for some help and advice. I took my Land Rover Defender 110 Double cab out for a run on Sunday morning, took the dogs for a walk and came home again. Nothing strange happened. After lunch I was going to go to the tip and I could not start it. The engine would not even turn over. Assuming battery I tried to jump it but still would not turn over. I even tried to roll it to see if the engine would turn over, it seems to be locked solid. I took the injectors out and it would still not turn over. There was no smoke or drop in fluid levels, all within limits, no high temps. Any suggetsions as to what is wrong and how to fix it? Cheers Quote Link to comment Share on other sites More sharing options...
cieranc Posted March 8, 2010 Share Posted March 8, 2010 Welcome in! Do you mean it won't turn over on the key? Have you tried winding the engine on the crank bolt, to see if it's the engine that's locked, or the starter motor in-op? Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 8, 2010 Author Share Posted March 8, 2010 Thank you for the welcome. I've been a lurker for a while and forgot it was my first post. Yes I tried turning it over with a spanner on the crank. Also rocked it in gear with injectors out so no compression and it still would not turn the engine easily. Whilst I could turn it with a fare bit of effort it made a schreeching sound and certainly could not be described as free. Quote Link to comment Share on other sites More sharing options...
cieranc Posted March 8, 2010 Share Posted March 8, 2010 Sounds like it's siezed then Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 8, 2010 Author Share Posted March 8, 2010 What is it that tends to seize? New to this deisel lark so pardon the daft question. Pistons? Crank bearings? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 8, 2010 Share Posted March 8, 2010 Starter motor may be engaged and siezed, which would in effect lock the engine up. I suggest you remove the starter motor and then try to turn the engine with a socket or spanner. Les. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted March 9, 2010 Share Posted March 9, 2010 seized alternator is also a possibility Quote Link to comment Share on other sites More sharing options...
Reiny Posted March 9, 2010 Share Posted March 9, 2010 seized alternator is also a possibility I second that. Happened to me. Alternator seized and engine stopped! Just remove the drive belt and try again. Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 9, 2010 Author Share Posted March 9, 2010 Thanks guys. Guess what I'll be doing later! Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 21, 2010 Author Share Posted March 21, 2010 Thanks to those of you who identified the alternator as the problem. Now i've replaced it the battery light will not go out. Any ideas? Quote Link to comment Share on other sites More sharing options...
western Posted March 21, 2010 Share Posted March 21, 2010 either that alternator is duff or the wiring is incorrectly connected. charge light on normally points to a dead diode inside the alt. Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 22, 2010 Author Share Posted March 22, 2010 That was my thought. Any easy way to test the alternator whilst its fitted? Cheers Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 22, 2010 Share Posted March 22, 2010 A good battery will give out 12v or slightly higher with the engine off. With it running on tickover - there should be about 14v at the battery terminals. Les. Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 22, 2010 Author Share Posted March 22, 2010 I guess as I have about 15v at the battery when the engine is running the alternator is OK but the diode pack is shot. Cheers all Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 22, 2010 Share Posted March 22, 2010 Just found a dealer on ebay that does the diodes and brush modules. Look in the parts request forum for my alternator post. Should be near the top. Hope that helps as they aren't easily obtained (from anywhere) by all accounts. Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 22, 2010 Author Share Posted March 22, 2010 either that alternator is duff or the wiring is incorrectly connected. charge light on normally points to a dead diode inside the alt. OK daft question of the day. Which way should it be connected? Cheers Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 22, 2010 Share Posted March 22, 2010 what wires to you currently have? There are normally 3 contacts B+, D+ and W The large brown cables should all go to B+ you'll have a small thin cable going to d+ and W probably wont have anything unless you've fitted a rev counter. Quote Link to comment Share on other sites More sharing options...
noise jammer Posted March 22, 2010 Author Share Posted March 22, 2010 what wires to you currently have? There are normally 3 contacts B+, D+ and W The large brown cables should all go to B+ you'll have a small thin cable going to d+ and W probably wont have anything unless you've fitted a rev counter. Thats what I have and and the light stays on. Best guess is duff diode. New alternator fitted at the weekend. So I think I've been unlucky. The parts shop are replacing it free though. Quote Link to comment Share on other sites More sharing options...
western Posted March 22, 2010 Share Posted March 22, 2010 check your connections against this diagram. Quote Link to comment Share on other sites More sharing options...
