Tom 200tdi Posted March 21, 2010 Share Posted March 21, 2010 hello i have fitted a 200 di from a disco to my defender just started using it and noticed that its running close to the red but the engine doesnt seem overly hot .what id like to no is.is the 200 tdi sender compatible to the original turbo diesal guage .hope you can help many thanks. Tom Quote Link to comment Share on other sites More sharing options...
western Posted March 21, 2010 Share Posted March 21, 2010 Discovery sender isn't a good match for the existing gauge, either use the original engines sender or the Defender unit PRC8593, do a search too as this comes up a lot. Quote Link to comment Share on other sites More sharing options...
Briarston Posted March 22, 2010 Share Posted March 22, 2010 hello i have fitted a 200 di from a disco to my defender just started using it and noticed that its running close to the red but the engine doesnt seem overly hot .what id like to no is.is the 200 tdi sender compatible to the original turbo diesal guage .hope you can help many thanks. Tom I have also done this conversion. I fitted the TD sender to it. When well warmed up, the gauge is near the top of the white segment, worrying at first, but shows no sign of being overhot, just as you say. Perhaps the more central mounting point on the TD engine gives a more "average" block temp. whereas mounted near the thermostat housing is the hottest part thus a high reading? Perhaps the way to go is as Western suggests - 200tdi Defender sender. I think I will try that myself! Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 23, 2010 Share Posted March 23, 2010 this is what i used http://www.demon-tweeks.co.uk/Store/Performance/Gauges_&_Dial_Kits/Gauges/TIM_Water_Temperature_Gauge_Electrical/813/1528 its much better than land rover gauges as it gives exact temp and it comes with different thread adaptors to fit, and is good value. Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2010 Share Posted March 23, 2010 the VDO Vision temp gauge & matched sender is a good alternative to the Factory LR gauge. VDO temp gauge Quote Link to comment Share on other sites More sharing options...
