kingrat Posted March 22, 2010 Share Posted March 22, 2010 Does anyone know if a 2000 TD5 has the relevant loom for electric windows and central locking as standard or do I need to go down the aftermarket route?. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted March 22, 2010 Share Posted March 22, 2010 Unlikely to have it as standard. You'll need a new loom - and they are cheap enough second hand. Might be a good time to upgrade to the newer dash? Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 22, 2010 Share Posted March 22, 2010 My 2001 (51 plate) 90 CSW didn't have them so I had to go down that route myself. I managed to find a couple of decent length convoluted rubber "tubes" from the rear doors of a biggish Rover (I think?) from the local scrappy to run the wires down into each door. I made up an interface to drive the lock motors with a pulse initiated by the 12v supply to the alarm volume sensor, this is switched on only when the alarm is set. I hope this helps. Clive Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted March 22, 2010 Share Posted March 22, 2010 if it didn't come with it. it doesn't have the loom. please do yourself a favour and change the window regulator to the original powered window ones. they are a lot faster than the bolt on ones and the bolt on ones force the door card out and hence closing the door is a little harder. Quote Link to comment Share on other sites More sharing options...
