sharpy Posted April 14, 2010 Share Posted April 14, 2010 Hi All, Several questions all about the same thing, is there a roof rack, by that I mean of the typical cage design that fits a 90, but only from where the slope of the roof finishes behind/above the cab and then backwards to the rear door? Has anyone got one for sale or has pictures of what they look like mounted? or a supplier? If there is such a beast available with it not stretching the length of the roof would it still support a spare wheel and still be able to function weight wise with luggage, etc? Think thats all? Cheers Paul Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 there are 3/4 length racks for 110, which can be a full length on a 90 but never seen a 3/4 length rack for a 90. Quote Link to comment Share on other sites More sharing options...
diver110 Posted April 14, 2010 Share Posted April 14, 2010 Yes Land Rover do one in thier budget version, I used to have 1 with a rear door spare wheel mount bolted through it to hold the spare. Specified weight is a problem with any roof rack because I think the LR recommendation from memory is 50kg max on the roof for stability reasons which probably isn't much more than the spare wheel on its own so in reality you need to ignore the recommended max weight to make any use of a roof rack????????? Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted April 14, 2010 Share Posted April 14, 2010 Patriot roof racks do a 3/4 length one for a 90. Not cheap, but the quality is out of this world. For the best deal go straight to the factory & speak to Paul Hogarth, the owner. Same as here, but obviously mounted further back: HTH Martin Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 Yes Land Rover do one in thier budget version, I used to have 1 with a rear door spare wheel mount bolted through it to hold the spare. Specified weight is a problem with any roof rack because I think the LR recommendation from memory is 50kg max on the roof for stability reasons which probably isn't much more than the spare wheel on its own so in reality you need to ignore the recommended max weight to make any use of a roof rack????????? 150kg roof load, this came up in the 2 weeks. Quote Link to comment Share on other sites More sharing options...
A Twig Posted April 14, 2010 Share Posted April 14, 2010 The current brochure states a 75kg recommended weight, loaded to as low a height as possible. Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 that's changed then, as my LR RAVE manuals, in the 2000 Td5 Defender owners handbook it clearly states 150kg max. the concerned page is in my reply in http://forums.lr4x4.com/index.php?showtopic=54902 Quote Link to comment Share on other sites More sharing options...
diver110 Posted April 14, 2010 Share Posted April 14, 2010 150kg roof load, this came up in the 2 weeks. Hi Western just quoting from LR hand books From Defender owners hand book second edition 2003; IMPORTANT INFORMATION Always observe the following precautions *The MAXIMUM load for approved roof rack systems is 75 kg for normal road use and 30kg off-road. Calculation of the maximum load must include the weight of the roof rack. The 50kg I previously quoted was from memory and probably from my Discovery 2 with calculation to also include the roof rack. I assume these figures are just arse covering because they would make a roof rack basically useless if you followed them to the letter. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 15, 2010 Share Posted April 15, 2010 Max roof load for a Defender is 75kg Now hold on.... For overlanding..it's 150kg Go figure. Try reading a little expensive book by Land Rover called "Working in the Wild, A Manual for Africa". Both weights are quoted in there. Quote Link to comment Share on other sites More sharing options...
