disco_al Posted May 12, 2010 Share Posted May 12, 2010 This is going to sound like a silly question, but which way up does the plate that bolts to the towbar go? i've bolted one to the back of the disco, and i'm not sure if it's the right way round pics would be nice. Quote Link to comment Share on other sites More sharing options...
Chris Rogers Posted May 12, 2010 Share Posted May 12, 2010 This is going to sound like a silly question, but which way up does the plate that bolts to the towbar go? i've bolted one to the back of the disco, and i'm not sure if it's the right way round pics would be nice. if you're talking about a dixon bate affair, the 4 holes on the slider want to be closest to the ground. As in these pics http://cgi.ebay.co.uk/LAND-ROVER-DEFENDER-90-110-ADJUSTABLE-TOW-KIT-1984-98-/280503534402?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item414f504342 Quote Link to comment Share on other sites More sharing options...
disco_al Posted May 12, 2010 Author Share Posted May 12, 2010 i may not have been clear enough the slider is straightforward enough to work out, it's the actual back plate that bolts to the truck i'm not sure about. Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2010 Share Posted May 12, 2010 the 2 crossbars of the adjuster part should be closest to the vehicle & the 2 bolt attachment plate that's nearest the end of the side plates should be uppermost [at the top] otherwise the slide plate & connecting pin won't fit. Quote Link to comment Share on other sites More sharing options...
Pwyll Posted May 12, 2010 Share Posted May 12, 2010 If your still stuck, call round after work. You can have a look at mine. Ooh, er, missus! Quote Link to comment Share on other sites More sharing options...
