SolihullBeast Posted May 12, 2010 Share Posted May 12, 2010 I would like to convert the old tired front end of my disco 200 to the 300 style (headlamps, headlamp finishers, grille etc) does anyone if there is a technical thread on this anywhere? is it a big job? I am aware that the headlamp box will have to be modified, are there any other things I should be aware of? Many Thanks Sam Quote Link to comment Share on other sites More sharing options...
russ3120 Posted May 12, 2010 Share Posted May 12, 2010 try this bud headlight conversion Quote Link to comment Share on other sites More sharing options...
SolihullBeast Posted May 12, 2010 Author Share Posted May 12, 2010 try this bud headlight conversion Thanks for the input, but what I am actually looking to do is just fit standard 300tdi lamps, not td5 lamps, the td5 lamps look like a lot more work! I don't think there is any wiring involved when fitting standard 300 lamps is there? Cheers Sam Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted May 13, 2010 Share Posted May 13, 2010 Im sure its just a straight swap? as there wasnt much change to the Headlamp pannels themselves. you just need the lights, and headlamp trim, and grille. Quote Link to comment Share on other sites More sharing options...
CBolton Posted May 13, 2010 Share Posted May 13, 2010 ...not a straight swap...doing this myself to my 200....the 200 panels don't have the cut out for the 300 light mounts and its not a flat panel either....not looked at the wiring yet...soon Quote Link to comment Share on other sites More sharing options...
Pwyll Posted May 13, 2010 Share Posted May 13, 2010 From memory, the two headlights have different mountings to the front bulkhead. The 200 has two lugs while the 300 has three. I think. Does the 200 not have tohose wrap around thingies around the headlights and indicators? If so, does this mean that the wings are a different shape? Quote Link to comment Share on other sites More sharing options...
disco_al Posted May 13, 2010 Share Posted May 13, 2010 It is possible to do. You need to talk to someone nicely who has got a 300 series to start with. Then armed with some cardboard, some biscuits/beer/cider/whatever they like, and an hour or two to spare, go and visit them. Then once bribed with pre purchased items, make some templates with the cardboard as to where to make some incisions. From memory the wings are the same 200/300 series (well they look the same) The main reason for the templates is to make it easier, as they do have three mountings as opposed to the 200 series 2 mountings. The other option is to find a scrapper and cut the mounting panels out and re weld them into yours. Although i'd prefer to use the template method Quote Link to comment Share on other sites More sharing options...
