getting more from a 200 tdi discovery engine
muddy4x4xfar
could you expand a bit on the above? how do you get more boost? what does this do to the fuel consumption?
You adjust the wastegate to open at a higher pressure.
I actually got slightly better MPG with it tweaked to buggery, probably due to not needing to change down & rev the nuts off it to get up hills anymore.
I think there is/was a link to a long thread on here about turning the power up on TDis, couldn't tell you where it was years ago i read it.
