SiWhite Posted May 18, 2010 Share Posted May 18, 2010 Evening All, 1. My ABS warning light is permanently lit in the dashboard, despite my not having ABS. I've tried pulling the fuses but it is still on. Any ideas short of snipping the wire? 2. My horn refuses to sound when the alarm is activated. The hazards work as they should but no horn. I have access to a Rovacom but cannot make any progress. Thanks in advance..... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 18, 2010 Share Posted May 18, 2010 Si, There is a workaround for the Td5 warning light panel for non ABS equipped vehicles. I used it when I put the later gauges in my 200Tdi. If I recall correctly you have to connect pin 10 to pin 6 and pin 13 to pin 9, both on the smaller of the warning light panel plugs. Pinouts as per here: http://www.retroanac...a-200tdi300tdi/ Hope that helps Quote Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2010 Share Posted May 18, 2010 Fit ABS!!!! Sorry Si can't help .... Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2010 Share Posted May 18, 2010 I used the ABS light as my Handbrake On light, so ABS = 'And Brake Stupid just in case I forget. Quote Link to comment Share on other sites More sharing options...
