TD5 Double Cardan onto RR Classsic?
Rotor
Anyone fitted a double cardan/uni joint front prop off a TD 5 Disco to a 96 300tdi RR classic with a Borg Warner? can it be done? do you need to change the output flange on either the diff or the transfer box?
Ta
Rotor
You will need to change the t box flange. Not certain of length compatibility.
Be warned, the Disco DC prop is rubbish - it is not greasable and so has a very short life. Better off shopping at Gwyn Lewis or the propshaft clinic if you really need a DC prop.
I've just bought wide angle props for mine from Mailorder 4x4 :P
Fitting them soon.
They also do double cardens - call Peter and chat to him. He double checked compatability for mine (200Tdi with B/Warner).
Link
HTH
