old leafer Posted May 21, 2010 Share Posted May 21, 2010 hi gents i was wondering if disco discs brake hubs will bolt on to the end of my drum axle or am i swaping the whole axle over regards mark Quote Link to comment Share on other sites More sharing options...
western Posted May 21, 2010 Share Posted May 21, 2010 if this is for a 90, it's quicker to change the complete axle. Quote Link to comment Share on other sites More sharing options...
old leafer Posted May 21, 2010 Author Share Posted May 21, 2010 if this is for a 90, it's quicker to change the complete axle. yep for a 90 but i can collect hubs easy however i will be divorced if i put axle in her belover g wagon Quote Link to comment Share on other sites More sharing options...
western Posted May 21, 2010 Share Posted May 21, 2010 AFAIK the hubs can be swapped, but not sure if the caliper brackets are welded or bolted to the Discovery axle casing. looking in my parts info, the Disco axle caliper brackets are part or welded to the main case, so that'll stop you just changing the hubs as your axle doesn't have any mounts for the calipers to attach too. hence why most change the complete axle to gain rear disc brakes. Quote Link to comment Share on other sites More sharing options...
jbs Posted May 21, 2010 Share Posted May 21, 2010 It's easier to just change the whole axle across to your 90 from a disco/late 90, they seem to be cheap and plentiful now so getting hold of one shouldn't be a problem, as Ralph says the brackets are indeed welded onto the casing, the late 90's(defenders) and discovery's share the same axle and whilst I think about it so does the range rover,but with that you'd be needing the late range rover axle(after 1986)as they changed the shock absorber mountings on the range rover axle from what I call stick and twist to both facing forward and the other thing to be mindful of with range rover axles after 1986 is they may be imperial bolt sizing's on there unlike the later 90/disco ones which should be metric thread sizes HTH John Quote Link to comment Share on other sites More sharing options...
old leafer Posted May 23, 2010 Author Share Posted May 23, 2010 thanx for the info gents new axle it is then regards mark Quote Link to comment Share on other sites More sharing options...
