natas Posted May 25, 2010 Share Posted May 25, 2010 What are the signs of a failing steering damper? I think since I installed my new bigger tyres that I need a new damper. Occasionally it I hit a bump on the road at speed I get a slight shimmy through the steering. I had the same problem with my CJ5, when I changed the damper the problem was solved. Thanks. Quote Link to comment Share on other sites More sharing options...
oakesy Posted May 25, 2010 Share Posted May 25, 2010 If the steering damper is original the check for signs of leakage. Also the shimmer effect might down too the steering box needing adjusting. Better advisor will come along shortly. Quote Link to comment Share on other sites More sharing options...
Naks Posted May 25, 2010 Share Posted May 25, 2010 Friend of mine is fitting a configurable steering damper. Basically a coil over system on the damper and you can then set the resistance of the coil to suit your needs. he needs it because he is fitting 35' tyres to a Puma SVX Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 25, 2010 Share Posted May 25, 2010 Time for a new steering damper, methinks. Mo Quote Link to comment Share on other sites More sharing options...
tyrone Posted May 25, 2010 Share Posted May 25, 2010 i put a tough dog coil over on my landy with 35's made so much differance well worth it Quote Link to comment Share on other sites More sharing options...
