Sabre Posted July 3, 2010 Share Posted July 3, 2010 My 300 TDi draws in a lot of dust when I travel off-road. The rear door seal looks past it's "sell by" date, and needs to be replaced. The car has, however, never been very dust tight, even when the rear door seal looked new. Any suggestions or other possible areas of dust ingress that I can try and seal ? Thanks in advance JZ Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted July 4, 2010 Share Posted July 4, 2010 Perhaps try adjusting the door latch on the pillar, if you move it further into the car when you close the door it will squish the seal a bit more, and hopefully seal better. I think they can be adjusted on these, you can on most cars. If your car lets in dust then water must be a pain! Quote Link to comment Share on other sites More sharing options...
Sabre Posted July 4, 2010 Author Share Posted July 4, 2010 Perhaps try adjusting the door latch on the pillar, if you move it further into the car when you close the door it will squish the seal a bit more, and hopefully seal better. I think they can be adjusted on these, you can on most cars. If your car lets in dust then water must be a pain! I'm in South Africa. What's this water thing you're talking about ? Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 4, 2010 Share Posted July 4, 2010 I'm in South Africa. What's this water thing you're talking about ? It's a bit like the stuff that comes out of the kitchen tap, but it falls from the sky Anyway, I have it on good authority it snowed in Jo'burg at least once in the last two years 25 months Quote Link to comment Share on other sites More sharing options...
mahon257 Posted July 6, 2010 Share Posted July 6, 2010 My 300 TDi draws in a lot of dust when I travel off-road. The rear door seal looks past it's "sell by" date, and needs to be replaced. The car has, however, never been very dust tight, even when the rear door seal looked new. Any suggestions or other possible areas of dust ingress that I can try and seal ? Thanks in advance JZ Had the same problem after a trip to the Sahara. Lots of fine sand - everywhere! My solution? 1. Buy a new Door Seal (about £50) 2. Adjusted both latch position and moved the top of the door towards the car, and the bottom edge out - by playing with the hinges. The 2 x hinges are fixed to the car on free-moving plates. There's a fair amount of adjustment - definately a 2 man job though... Quote Link to comment Share on other sites More sharing options...
teabag Posted July 6, 2010 Share Posted July 6, 2010 As above but buy a LR "genuine part" seal as they work, pattern may not. Quote Link to comment Share on other sites More sharing options...
