Donald Sherburn Posted July 10, 2010 Share Posted July 10, 2010 Have removed all of caliper and pads AND two screws in front discs ...cannot budge discs to replace. Any way apart from BIG hammer to remove, would heat from blow torch affect anything? Any way to cut disc off with angle grinder? Have shiny new discs and pads ready to replace so not bothered about old discs. Any help would be gratefully appreciated, thanks in advance. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 10, 2010 Share Posted July 10, 2010 Smack the back of the disc with a mallet/hammer, turn the disc 180-deg, then do the same again. It'll come off eventually. Les. Quote Link to comment Share on other sites More sharing options...
rustymark Posted July 12, 2010 Share Posted July 12, 2010 Make sure the driveshaft end nut is not also holding the disc in place....... i can't remember without looking on RAVE if this is the case! if not you could also use a large bearing / hub puller to shift it. Quote Link to comment Share on other sites More sharing options...
v8bertha Posted July 15, 2010 Share Posted July 15, 2010 Make sure the driveshaft end nut is not also holding the disc in place....... i can't remember without looking on RAVE if this is the case! Nope... not the case No need to touch the driveshaft nut. As Les said just thwack it one! Quote Link to comment Share on other sites More sharing options...
