Grant. Posted July 13, 2010 Share Posted July 13, 2010 Hi all, My 90 has a set of +2inch scorpion racing springs fitted(Bright orange!! ) and the ride is incredibly hard! Was wondering if that is normal for a set of those springs? Or could it be the shock bushes are to tight and need slacking off a little bit? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted July 13, 2010 Share Posted July 13, 2010 You sure its not just riding on the bump stops under your belly only joking! Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 13, 2010 Share Posted July 13, 2010 Could be the rate of the spring is just too high. Dont know what you mean about slackening off the shock bushes?? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 14, 2010 Share Posted July 14, 2010 I had +2" scorpion springs on my last 90 and they were nice and tall and soft, lovely off road Quote Link to comment Share on other sites More sharing options...
Top90 Posted July 14, 2010 Share Posted July 14, 2010 Sounds like the spring rates may be too high. Try loading it up with some weight and see if it's any better. If so, then that's the problem = You need softer springs. Quote Link to comment Share on other sites More sharing options...
Grant. Posted July 14, 2010 Author Share Posted July 14, 2010 okie dokes wil try that! Wasnt sure if it could have been that the shock bushes were overtightened as to not allow any movement! And cheers sutty! Will go get the scalpol, see if it makes a difference Quote Link to comment Share on other sites More sharing options...
