pinhead Posted July 19, 2010 Share Posted July 19, 2010 drove home last night fine girlfriend jumps in to go to work cranks over but wont start come home cant find an obvious fault stinks of petrol look underneath and it is running down bell housing big time now its got a bit late and dark but is there any thing that is the usual fault to give me a head start in the morning cheers andy Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 19, 2010 Share Posted July 19, 2010 I guess one of the fuel lines may have chafed through on something, not sure of any usual faults, have not had any problems on mine. The pump is in the tank so a loss of pressure would mean no fuel to the injectors = no start. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 20, 2010 Share Posted July 20, 2010 If you can get someone to turn on the ignition while you look around the rear of the engine with a torch the problem should become apparent. The pump will only run for a couple of seconds, but in that time it should shift plenty of petrol for you to spot, but if poss you should wear safety glasses and have some rinsing water nearby in case it squirts you... Quote Link to comment Share on other sites More sharing options...
pinhead Posted July 20, 2010 Author Share Posted July 20, 2010 Well just got this sorted fuel pipe had come off but to get at it I had to take inlet off not too bad a job unless you trap a wire putting it back together and have to do it all again but with the extra work of mending the injector harness hay ho it's all ok now though Quote Link to comment Share on other sites More sharing options...
