Can you help again please - battery light has come on
Hi my 1994 defender battery light has just come on after driving 40 odd miles. I have a voltmeter and it is still reading 13.5 when the engine is on and 12 when off...
My batteries are both about 12 months old and seem really good (their the maxim type or whatever there called)
Any ideas where to start looking and why it would come on when all seems fine and dandy?
Cheers
even though the volt meter is shownig its charging fine? seems really odd
13.5V isn't "charging fine", it's just "charging". An alternator in 100% nick running at a few 1000 rpm should be giving you 14 - 14.5V.
Have you measured the voltage accross the big terminals on the back of the alternator, to eliminate a bad earth problem? What reading is the warning light terminal giving you? if its more than 14.5V then as Ralph suggested it could be a regulator pack fault.
Hi bit of an update. It is the alternator that needs changing.. i bought a second hand one from a 300tdi discovery however the pulley is different. I have tried to change it over but cant for the life of me get this one off, any ideas or tips? Also thought i might just get a new one and it seems the 65amp replacement part is £110 and the 100amp upgrade is £100 however i would will still need to change the pulley or buy a different belt? I'm a bit confused now can someone shed some light i just want to get her charging again with a simple bolt in bolt out job without having to change the belts as (i bought a few spare this size) and if i can upgrade it if it wont cost much to do so ...
thank in advance
Confused Will
It's a while since I did it, but it went as follows:
1) undo the pulley securing nut so that it is still on but right at the end of the thread
2) clamp pulley in Workmate so that alternator hangs down underneath
3) apply small amounts of 3-in-1, WD40 or Plusgas to threads
4) make and deploy beverage of choice
5) put a bit of scrap timber over the nut and tap authoritatively with LR special tool No. 1 (hammer) until the alternator drops onto the nut.
Don't hit it very hard, as you can break the lip off the pulley and / or knacker the bearings, but it will go eventually.
if you've gone for the 100amp Alternator upgrade the main brown cables to the battery & starter motor otherwise you'll have more problems later.
another run of cable, the same size as the existing wires & attached to the same place both ends will be fine.
prob is you cant hold an Allen key on it with a nut on it. think ill drop it in and use an air gun on it.
With the upgrade on the wiring that goes from alternator to start motor to battery can i just add another wire from alternator straight to battery?
Cheers
Cheers
as I posted above -- another run of cable, the same size as the existing wires & attached to the same place both ends will be fine
but you need to find out what size cable is already fitted, so you can have either a new much thicker cable or 2 lengths of the same original size cable to battery & starter.
