need4speed Posted August 3, 2010 Share Posted August 3, 2010 Just wondering if anyone could help me decide which wiring loom i need to get for my 110. Spec will be as follows: TD5 chassis fitted with megasquirted RV8. Plastic TD5 fuel tank fitted with 4.6 RR fuel pump. Im hopeful that a standard V8 110 loom will do, but just would like to see if anyone has any thoughts.. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 3, 2010 Share Posted August 3, 2010 I'd got for whatever matches your dashboard & switchgear and do the MS separately with its own relays & fuses. Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 3, 2010 Author Share Posted August 3, 2010 Im intending to do the MS separately. Im just wondering what loom i need to get as i dont have one at all just now. You see im at the stage in my build where im ready to get the rear tub all fitted onto the chassis but cant fit the tub until i have the fuel pump wired up... I was hopeful that all the switchgear / dashes were the same on all the defenders apart from the very latest ones? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 3, 2010 Share Posted August 3, 2010 You'll probably need the fuel pump connector as that won't be the same. Quote Link to comment Share on other sites More sharing options...
need4speed Posted August 3, 2010 Author Share Posted August 3, 2010 So, that being the case will any 110 loom do? Quote Link to comment Share on other sites More sharing options...
western Posted August 3, 2010 Share Posted August 3, 2010 Depends if you want glass or blade fuses, 300Tdi/Td5 plug & socket type or the older bullet type connections, which lights,instrument pack & switches, lots of things which differ over the years of the 110/Defender110 range, might be easier to build the loom up as you go, the correct wire colours are available, plus the finshed wiring loom will not match any wiring diagrams in the workshop manuals Quote Link to comment Share on other sites More sharing options...
