Hybrid_From_Hell Posted August 7, 2010 Share Posted August 7, 2010 Big Ends, Mains and Rods - all need to be replaced, although there is virtually no real wear, and the journals are std. I have some part No's, could some kind soul tell me what they are off LR or Engine wise / age etc They look like vandervell (VP) in a circle - Con Rods : ERC2587 one end - 5051 KF the other Mains and Big Ends etc ERR1762 std and also 'G' in a box and CD ERR1765 and then VP HD 7300 other end As its a serp engine I'm guessing these may be late std 4.6 Parts ? (Fingers crossed) and not £Exo£tic£ ? ?? Also all the Main Bolts washers and cross bolts for the block and washers are missing Can you advise of the 10x Mains parts, and criossbolt parts for a 4.6 block and if the same as a serp 3.9 Block (Think they are) A pic of parts would be good too if my luck hasn't pushed whoever (prob Ralphy ) Too far Nige Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2010 Share Posted August 7, 2010 Con Rods : ERC2587 one end superseded by RTC2117 5051 KF the other not recognised, not a LR part number. Mains and Big Ends etc both not recognised in microcat or on a search of Craddocks/LRSeries/Google websites ERR1762 std and also 'G' in a box and CD ERR1765 and then VP HD 7300 other end main bearing set standard size for a 4.6 V8 is STC4299 add 010 or 020 to the end for 10 or 20 thou undersize bearings. ERR1772 con rod bolts x 16 602130 main cap bolts qty 10 FB110137 M10 x 65mm qty 8, washer ERR3330 qty 8. [not knowing V8 intimatly like you do, I think these are the cross bolts & washers, see diagram below] Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 10, 2010 Author Share Posted August 10, 2010 Ralphy Can you check ERR3330 ? Says Oil Seal on LR Ordering System Nige Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 10, 2010 Share Posted August 10, 2010 That's correct Nige, it says oil seal but is actually just a washer that sits under the cross-bolting bolts 'SEAL 19MM OD, PETROL V8 L/R EFI' #5 on Ralph's screenshot. Quote Link to comment Share on other sites More sharing options...
fozsug Posted August 10, 2010 Share Posted August 10, 2010 Mains and Big Ends etc ERR1762 std and also 'G' in a box and CD ERR1765 and then VP HD 7300 other end Nige Can JE not help? If not if you take them to Banda Engineerining in Portsmouth 02392 828224,she will match them for sure Quote Link to comment Share on other sites More sharing options...
western Posted August 10, 2010 Share Posted August 10, 2010 Ralphy Can you check ERR3330 ? Says Oil Seal on LR Ordering System Nige This is it on RimmerBros website has a photo too http://www.rimmerbros.co.uk/Item--i-ERR3330 Quote Link to comment Share on other sites More sharing options...
argonaut Posted September 18, 2011 Share Posted September 18, 2011 Just dragging up an old thread here as I am stripping my engine. I also have main bearings identified as "ERR 1765" - can anyone shed any light on what they might be? Microcat couldn't recognise that number at all. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2011 Share Posted September 18, 2011 I can't find ERR1765 antwhere either in my parts info or via a google search. Quote Link to comment Share on other sites More sharing options...
