Distance between crank and cam centres?
Night Train
Why are you looking into this Night Train, you want to change the gearing? :ph34r:
I just need a small cheap drive train on a project and the centres need to be around 6" to 6.5" or a bit more for clearance. A timing chain and sprockets would cost less as a bodge then getting the right stuff, and work just as well.
Not lost enough marbles to change the speed on a cam, well, not yet. ;)
